Copy/Move dialog box Error - "Parameter is Incorrect (87)"
Hi: since upgrading to DOpus12 12.2 x64 (build 6109) I have encountered errors when moving/copying, when I use favorites to specify the target directory.
If I paste in the exact same target-string, it works. (I copied the target string from opening the edit favorites dialog).
Any ideas what is causing this error(87) and how to fix it?
Confirmed. That looks like a bug on our side. Leave it with us.
A quick work-around for this 'bug' is:
type a terminating backslash to the proposed string, and the dialog will generate a list of sub-folders within that folder;
You can then select one of them, or leave the string as-is (with \ at the end) and the Copy/Move operation succeeds.
In addition to fixing this 'Parameter is Incorrect (87)' bug, it would be nice for the dialog to populate the directory tree to the proposed folder-path (as it once did). That was very convenient, although selecting the sub-folders as described above works for now.
This has been fixed for the next update.
Another temporary workaround is to turn off Preferences / Folder Tree / Contents: Quick Access if you don't need the Quick Access folder to be shown in the tree (also affects the main folder tree in listers).
