Copy movewhensame with Teracopy
Hi everyone,
whenusing the default handlers of DOpus (or explorer) for copying/moving files via drag-and-drop, the files are copied if they are on different drives, and moved if they are on the same drive.
Now I have integrated TeraCopy as default handler for copy/move operations (using this topic).
Is it possible to create a similar behaviour ("copy movewhensame") using TeraCopy ?
Not by the look of the TeraCopy command-line arguments:
help.codesector.com/TeraCopyCommandLine
(At least, not adding a layer of scripting glue between Opus and TeraCopy.)
Maybe there is a way, though. If anyone knows it's the people who make TeraCopy:
codesector.com/support.php
