When I want to copy paste - impossible dopus asks me to put myself in administrator mode how do we do it ?? thank you to you
You should only be asked to elevate if the action failed due to an Access Denied error.
Can you paste the same file to the same folder using File Explorer? Does it also trigger a UAC prompt?
The problem may be due to folder permissions. Or it could be antivirus blocking the action. (There is no way for software to know why an Access Denied error happened, so when one happens Opus will ask if you want to elevate, since lack of permissions is usually the reason.)
Thank you leo I cut my antivirus and copy paste it worked fine
thank you again for your quick rest
