Copy settings
How to copy preferences/listers from one installation to another installation.
Are you asking about just the specific 'Listers' settings as opposed to all Dopus Preferences? Are you familiar with the Settings->Import and Export.. option? This saves all (or selected) Dopus settings to a single file, but I do not believe there is any way to limit what is saved to only the setting on the prefs page you mentioned...
