Copy unattended, then shutdown
I offer: to add in "dialogue copying in progress" checkbox "shutdown on successful done". It is very convenient option for longtime copying (for example FTP). Real situation. Started copying on FTP of two files in total volume 35GB. Copying went 13 hours, but in 3 hours I left the home for 5 days, and cancel copying could not for some reasons. The computer idled nearly 5 days, spending the HDD resource and energy.
The schedulers, who are automatically shutdown the computer in due time, in such situations it is impossible to use. When copying there can be a situation demanding the users answer, and then it is necessary to look answer, as much as long.
gpsoft.com.au/help/opus10/de ... ration.htm
Unattended operation dialogue it is good, but..... In the above described example from life I used this dialogue, however, the computer all the same fulfilled 5 days idle as in this dialogue there is no option shutdown on done successfully. The offer staying actual.
If you want the computer to shut down when the copy has finished:
Thanks! It works really.
