but ignoring the content of all subfolders, as well as the subfolders themselves, as in G:\pictures\one\sub1, etc.
I figure, it can be done quite easily through the copy filters, but i haven't been playing around with copy filters
(or the filter system generally) that much, so i don t have a good idea, how.
Hmm, that was an example only. It's changing folders all the time, so i can't hard code them im advance.
I woul start selecting the folders, & the filter should know, i only want the jpgs inside of those folders.
Until now i'm using some code with my old "folders only" copy filter, navlock=toggle, & have been putting the files
into the copy queue manually, but i'd like to speed things up a bit.
I doubt that that can be done since the command only copies files (it can preserve their timestamps), creating a new folder to put them in (which has no real connection to the old folder, as far as the command is concerned; i.e. the creation time of the new folder is the time it was created).
Maybe i have to stick to the old way then (using the old copy filter). I had a look in the "copy attributes" section of the manual,
but there seems to be no way of extracting the time stamps from folders, to copy them over the new ones.
I have all those folders in the format dd'-'MMM'-'yy, which i want to keep sorted by created date. It wouldn´t be bad, if Opus could
"understand" the sorting of this type of folder names, but i guess that would be too special, since i don´t know, if many users
use this type of folder naming.
