I didn't understand why that happened with my second external HD but now you've solved the mystery. My drive was indeed B: and when I now changed it into M: the grinding noise stopped and copy speeds went back to normal.
This happens only with Opus. I've tried it with Explorer, xcopy and Robocopy and it doesn't happen with them.
I'm told that the fix for A:/B: HDD/network copy speed in 9.5.1.0 may have an unwanted side-effect where copies to removable drives (on any drive letter) may now be slower. That's being worked on.
So if the A:/B: issue affected you, 9.5.1.0 fixes it, but if you find copying to removable drives is slow 9.5.1.0 then stick with 9.5.0.0 for now.
Just experienced extremely slow file copy, on external USB drive L: in version 9.5.0.1. No problems when copying with Windows Explorer.
Will wait for 9.5.2.0.
