I often use the very helpful right-click drag method to copy picture metadata from one file to another. I've noticed though that when I choose "Copy all picture fields" it doesn't include the 'Tags' field. I typically use this field to store picture keywords.
I suspect the 'Tags' field doesn't really count as a proper picture field when copying metadata, so this is a feature request for a future release. Would it be feasible to add support for copying 'Tags' field data?
I seconds the feature request.
I was super excited when I read in the manual that you can effectively batch copy metadata via drag&drop ...
and I was super disappointed when I realized that the only metadata that's of interest to me - "Tags" under "Extended Properties" - cannot be copied via left- or right-click-d&d.
Is there a technical reason for that? The request is from 2021, a long time with no response for something that seems to be a rather small fix or addition.
Hear, hear. Easier access to photo tags is the only thing keeping me from using Dopus more for photo organization. I want to copy and insert photo tags easier.
' Set strNewName to an empty string so that Opus does not rename the file
strNewName = ""
Set objShell = CreateObject("WScript.Shell")
objShell.Run strCommand, 1, False
Set objShell = Nothing
End Function
That's the code to copy your tags into the clipboard. To paste it, just use the command at the bottom.
I have both commands assigned to some hotkeys.
Note, that you can't use this code for batch jobs, it will work only for single files. And thanks again to the guy from the forum here, who provided the script.
In case it helps with the script above, if you create a new button for it, set it to the "Standard Function" type, not "Script Function".
(The first line is outside the script, and is running the Rename command. The script below that is attached and gets run by the command. So while it is mostly script code, it's considered a Standard Function. If you're wondering why it uses the Rename command when it's not renaming anything, It's because this used to be a tidy way to have the script inside the button instead of in a separate file. Still works fine today, so no reason to change it, but you don't see it that often as there are more direct ways now. Just thought it might be worth explaining for people who haven't seen it before.)
I discovered drag and drop to copy some metadata by accident a while ago:
but I can't find anything about it in the manual.
Where is the info in the manual? Can someone please post a link?
I just did a quick test, and "Copy All Picture Fields" did copy Title and Description fields, but not Tags or Ratings, which seems strange since Tags, Ratings, Title and Description are stored in IPTC or XMP fields.
Date taken was also copied, and that's great!
So, currently, "Copy All Picture Fields" is really "Copy Some Picture Fields".
The CopyMeta Script Command does not copy the 'Date Taken', which is very important for photos.
So, If "Copy all picture fields" really did copy all picture fields, it would be amazing!
Thanks for the link. The reason I didn't find it was that I searched using combinations of the words: copy, all, picture, and fields, but those words are not in the text.
On that same page, 'Picture fields' does not have a definition, but 'Picture Properties' does. Is 'Picture fields' supposed to be the same thing as 'Picture Properties'?
So what does this mean for the feature request and actual topic of this thread?
You've commented on everything except that.
Ixp's "CopyMeta" is great like all the other scripts he's posted, but it's more like a workaround most people wouldn't need if the existing function got fixed/extended.
If I had anything useful to share about that, I would have. We're aware of the request but haven't committed to doing it, or not doing it, at this stage. Personally, I haven't been involved with the code that would need modifying and don't know what the change would entail without investigation. As a team, we're finishing other work and have a long, categorized list of ideas (including this one) for the future which we go through when we're doing other work in the same area, or when we finish work in one area and need to decide what to do next. Until then, it's unknown.
I may still reply to a thread with other information I think is useful, which doesn't mean the original request is being ignored; it just means there is no yes/no answer or timeline at this stage. Demanding a definitive response to something when there isn't one will just make me more likely to stay silent in general.
Ok, thanks.
I get that it must be tedious to write detailed answers when you can't actually make any definitive statements.
But I've kinda noticed a habit of you to not say anything in those cases and it sends the wrong message.
If the issue is one of many points on one of many lists, just tell ppl exactly that.
Even if it's disappointing, it's not as unpleasant as the impression that you're being ignored.
Ignored? In this forum? Ok, I still have to take out the trash and walk the dog on my own, but other than that I think we are getting all the attention we need (and probably more than we deserve).
You are trying very hard to take that bit out of context.
That wasn't meant as an attack, so if this is your way of showing Leo your support against the rude noobie then it is unnecessary.
If we have no useful information then what is the point in us posting? What will anyone get out of it?
Have you noticed that most developers won't even talk to users? Sometimes I start to understand why.
It should be obvious that that is the case. Look at the number of requests on the forum. We should not need to state this on every single post. We simply don't have time to. We're trying to write the software as well, remember.
I've responded to several of your posts recently, so hearing you say that makes me wonder what you expect. Most developers would not even be talking to you, especially on a weekend. You can see from my account activity on here that I'm hardly ignoring people.
You can assume we read every suggestion and take it on board, even if we don't respond to it. I posted in this thread, so you can assume I read the suggestion at the top of it.
If we definitely won't do something, we typically say. If we say nothing, it's because we aren't sure about it yet (both whether to do it and when it would get done).
Oh Man !
Well, it is good to know that we are all human.
I have a simple piece of advise with an American twist.
Give credit where credit is due !
Is Directory Opus worth continuing ?
I watched a German movie recently called Der Tunnel.
Based on a true story of a 145 meter Berlin tunnel in the 1960's, I found myself needing English subtitles and at the same time hating them as they were so inaccurate.
Fritzi's reply to the question is wonderful.
Sorry, but this really reminded me of the German.
I really need a transcription to get it all, but I got that, almost; and 5 year olds.
Sorry, delete this if you prefer.
With respect to all.
