I currently testing Directory Opus 10.1 for couple of days and have some questions:
Initial Rename
If I have: New Text Document.txt and I rename from clipboard (where accidentally have space to end) to Dokument3 .txt is any way to disable space on the end to get automaticly Dokument3.txt?
2 Extracting from rar
I want to extract files from rar to parent directory, i use Copy "{filepath$|ext=rar}" EXTRACT TO "{filepath$|....}" and thats properly work, but when extracting i can not enter in any directory. I can click on any directory, but i must to wait to extract and than can enter in directory.
Thanks for answer
I try Copy Extract To .. (doing what i want, thanks) and notice that I have problem only when I want to extract file on double middle click (file types -> find .rar -> edit -> events -> middle double-click) only that when files extracting is not possible to enter in any folder, must to wait to extract complete.
If I make new button or context menu in file types extracting work properly and i can entering in any folder when extracting, no wait.
