Instead of bumping the older thread I decided to write a new one.
I just found out something that's really annoying. Whenever I run my Antivirus, DOpus CPU usage climbs way up. Opus uses around 35%-50% of the CPU while the anti virus usually takes another 40%, which leave my computer really sluggish and unable to even play a video without skipping big time.
In a sense I'm pretty happy to have found the cause of these slowdowns, they were driving me insane!
Anyway, if I close Opus while the antivirus runs, all is fine. But the Antivirus is not the only thing affect. The TortoiseSVN cache process is also and I think all apps that work with files are too.
Using Process Monitor I found out that for every file the antivirus scans, every file an application saves, etc, Opus gets several notifications.
Here is an example. I have a clipboard manager that runs from my Z: drive and saves text I copy to the clipboard to files on that drive for later reuse. With Opus open and displaying only the C: drive, whenever my clipboard app flushes its data to disk, Process Monitor reports more than 3000 events for DOpus.exe alone! DOpus seems to be doing something for all files saved by the clipboard app, and then much more.
Is there anything that can be done to prevent Opus from doing that, aside from closing it? I managing files all day long and Opus has been a real life saver, especially since Windows Explorer in Vista is clearly targeted at brain-dead users and is full of big bugs.
I'm attaching the event log from Process Monitor where I started capture, copied text to the clipboard and quickly stopped capture. In just a few seconds, Process Monitor recorded more than 3600 events.
I hope this behavior is not "as designed"... All other file managers suck, including the new Total You-Know-What!
Thanks.
OpusTest.zip (111 KB)
