Crash while using Auto-Complete for Evaluator
Crash while using Auto-Complete for Evaluator in a function button
Crash log ID: 650
Couple of old crashes were included in the submission with the two new ones. Those look like they were caused by OpenHashTab64.dll FWIW.
Is the auto-complete crash reproducible? Based on the DMP I can't tell why it happened, but it does look like there is a bug there somewhere.
Yes, that is very likely the old bug in OpenHashTag. I've reported it, but a fix hasn't been published yet.
I've been experimenting with the new array functionality, but haven't been able to reproduce the issue. I'll play a bit more :slight_smile:
Crash log ID: 651
Same situation as before. Crash after pressing TAB to get the auto-complete word. Not for the new Array functions, but for a variable.
Not easy to reproduce, I used the autocomplete countless times today without a crash.
Can you identify a specific situation that causes it? E.g. a particular script, or editing on a particular line or cursor position, etc? Not been able to reproduce it here so far.
Unfortunately, no. I've tried my best over the last two days :slight_smile:
Both crashes happened
  • in a function button
  • with pure Evaluator code
  • after a bit of experimenting/editing and testing with F5
  • after not having saved for a bit
  • in lines 3 and 6 (around)
  • immediately after hitting TAB
Side note: A couple of weeks ago, I needed to replace one 4K monitor with an FHD one, which forced me to run mixed dpi settings. Moving dialogs around occasionally causes hiccups - could this be related?
