I navigate to a folder with pdfs, right click on the columns above the filenames, select other->pagecount and Dopus crashes.
I also have pdf x-change installed as default viewer, but have setup pdf files open in sumatra pdf when i double click on a file inside dopus.
Directory Opus Pro 10.1.0.1 (4605) x64
OS 6.1 (B:7600 P:2 T:1) SP 0.0
hm, you're right, it's not a specific pdf. Not only that, there doesn't HAVE to be a pdf on the lister !! I just tried to open a pagecount column on a random folder and it crashes.
Before, something new happened. I would activate the pagecount column, nothing would happen, and then as soon as I would click on a drive button, crash.
Btw, when I said crash I meant the dopus window just vanished. But now I got a real program crash. I m not sure that helps, but here you go:
Problem signature:
Problem Event Name: BEX64
Application Name: dopus.exe
Application Version: 4.0.3.17
Application Timestamp: 50246861
Fault Module Name: MSVCR90.dll
Fault Module Version: 9.0.30729.4926
Fault Module Timestamp: 4a1750b0
Exception Offset: 0000000000054fc0
Exception Code: c0000417
Exception Data: 0000000000000000
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1032
Additional Information 1: 4301
Additional Information 2: 4301fb7e41ad61cc9fbee6b42e35bf5b
Additional Information 3: 2468
Additional Information 4: 24682554d85c611b04a546563f50b5b6
Just to check, is this the page count column that Opus provides (Documents / Pages) or is it one provided by a shell extension (in which case it would be in the Other category)?
the shell extension one. I just replicated it in my laptop btw. (although they have an identical configuration).
Also, I should note that none of the two columns seems to be showing pagenumbers for my pdfs! for ANY type of pdfs. I think Leo told me once that it's supposed to just show .doc file page numbers.. are there any plans for adding pdf pagenumbering?
If you can work out which shell extension it is that's adding that column we can try and reproduce the crash here.
I'll look and see if adding support for PDF page count is possible.
@MrC you're right, it's probably the same one... there is a 'pages' column in explorer, but I don't know which program it belongs to. It didn't seem to vanish when I uninstalled libre.
I installed LibreOffice and found Opus exited/crashed if I added the LibreOffice "Pagecount" column to Opus and then navigated to a directory with a PDF in it.
We'll blacklist the LibreOffice shell extension in the next update as a workaround (as I doubt it'll be fixed it any time soon, from past experience with the project).
If you want to manually block the shell extension before the next update:
[ul][li]Open Settings -> Preferences / Miscellaneous / Advanced.[/li]
[li]Double-click ignore_context_menus.[/li]
[li]Add {C52AF81D-F7A0-4AAB-8E87-F80A60CCD396} (including the braces {...}) to the list and click OK twice.[/li][/ul]
