When using the ROM Properties extension, calling the properties of several file type (.md or .d64) leads to a crash with:
Error oxc0000005 in Thread Ox44e4 at ox0000000300000002
Some extensions (.gb or .snes) work, as well as thumbnail creation.
[win32] RP_ShellPropSheetExt_Private::SubtabDlgProc(): Return FALSE instead of calling DefSubclassProc().
This usually didn't cause any problems when using Windows Explorer,
but Directory Opus appears to do its own subclassing. The end result
is Directory Opus crashes when selecting the rom-properties tab in
file properties.
NOTE: Since it's a dialog procedure, it needs to return FALSE instead of
calling DefWindowProc, and definitely not DefDlgProc.
