DO has started to crash on start sometimes with a error dialog pointing to a memory issue, reinstalling didn't work and I'm not sure what to do. I've already removed all network locations as the last open window when the first crash began was open on a network location and disabled all startup services.
I'm working on a day old windows 10 install, latest versions of OS and DO.
That is meant to be located at \Users\%username%\AppData\Local\Temp if I am correct?
There are no dump files located there, instead I've used the create log from task manager, on a DO task that was already running and on the task as I opened DO but am unable to upload here so I have emailed a link to a cloud folder containing the dumps.
