Create a hyperlink using a context menu
Is there a way to add to the context menu a command to create a hyperlink in word ?
Right now one can copy the name to Word document and then Ctrl K
that name in the document and copy the full name from DO as the link.
Can that be automated ?
This seems more a question about Word than Opus?
You can use Opus and ActiveX to create a new document and paste a shortcut into it. Pasting the shortcut into an existing/open document is probably more difficult and a job for which Autohotkey seems to be the better choice.
Thanks lxp,
Indeed pasting Hyperlink into an existing & open document (Word, Excel, Access) is what I am looking for. That seem to be a useful extension. I am surprised that it comes up only now.
Sorry, I am not an expert in Dopus. What is Autohotkey. Where is it in Dopus ?
Then it's really more a question about Word than Opus.
You'd need to write a VBA macro that gets the info from the clipboard and creates the hyperlink. Handling the clipboard looks painfully complicated:
https://learn.microsoft.com/en-us/office/vba/access/concepts/windows-api/retrieve-information-from-the-clipboard
Guess not too many people use Office as a file management tool :wink:
What is Autohotkey.
www.autohotkey.com
thanks lxp
