I've not found any info in any of my searches whether Opus-10 can or cannot create an Audio CD.
I suspect it will burn a data CD and possibly an MP3-CD but can I use it to create Music CD's?
Hi beclause,
It is quite easy if you are using Win7.
- Insert your blank CD. Cancel all the dialog boxes that windows pop up.
- Open Opus, and select all the fine tunes you want to record. Remember, it is all about the total TIME length of the songs, NOT the total size i.e. just because you can fit 50 mp3's onto a CD does not mean 50 songs will fit when burnt in audio mode. I can not state that important distinction enough.
- Right Click -> Send To -> Your CD Burner
- A Banner will be displayed with a link to burning the CD, click on the link
- A Dialog will open allowing you to modify the CD Label, Burn Speed and if you want the wizard to close or not after use, make your choices
- Click Next
- Click Make an Audio CD
8 Click Next - Windows will open Windows Media Player, click Start burn under the Burn tab & Whey Hey
I hope that helps,
Stu.
