question, would it be possible to set a command in Stream Deck, to make a new folder everywhere in Directory Opus when pressing a configured button?
That would be interesting to me, would be interested in having a command for just a creating a new folder and maybe a command to create a new folder with a designated name.
CreateFolder is the Opus command for doing that. (You can discover it by editing the New Folder button on the default toolbars. Useful if you need any similar commands.)
To have the Stream Deck tell Opus to run that command, configure the Stream Deck to run this command:
I'm not sure if the Stream Deck's built-in method for launching programs supports passing arguments to them (it's extremely basic), but there's a free add-on which lets you do that, along with some other other things that can be useful when launching things:
If the launcher you're using wants the program and arguments separately, they would be:
Program: C:\Program Files\GPSoftware\Directory Opus\dopusrt.exe
Arguments: /acmd CreateFolder NAME="My Folder" (or similar)
