Create Self-Extracting Archive - default path bug?
I trying to use the Create Self-Extracting Archive feature for the 1st time on Opus 10.2.0.0 (4645) x64
The main problem i have encountered is it will not allow me to enter the full path for extraction.
The full path is:
C:\Games\Eagle Dynamics\DCS World\Mods\aircrafts\Ka-50\Cockpit\Scripts\ABRIS
But it truncates it to:
Once the 'default path for extraction' field is full it will not allow any extra characters to be entered.. it just 'pings' at you.
Am i being thick or is this a bug?
leo, any feedback on this?
Confirmed, we'll fix this in the next update.
That dialog is resizeable, so as a workaround make it wider and you'll be able to type a longer string.
Thanks Jon, that workaround works for me. Simple, but i didn't think of that.
