Hi,
Are there any future plans to add an image cropping feature to dopus? At the moment I use paint or photoshop, but it would be good to do this from within dopus.
Many thanks!
Hi,
Many thanks!
There's one in the image viewer.
Push F1 to open the manual, then type "crop" into the search tab and it'll find the two relevant pages with more info.
that's great! thanks leo
Wow, just found out about this, really awesome feature.
Wait, there is? I don't see it. I also looked it up in the manual but nothing for "crop" was found.
Are we looking at the same manual?
Woops! Sorry, I was searching by using "Index" of key words instead of the actual "Search."
This is super cool and a real timer saver. It would be very helfpul if you could adjust the selection rectangle after dragging it out initially.
I dream of that too...
