Hello, The status bar in the standard text viewer shows total number of lines and bytes but no information about a cursor location (line number and position). Is this feature available in the viewer? If not, IMHO it would be nice to have it.
Best regards, Toller
You might want to check out the SourceCodeViewer plugin as it has this.
Nudel, Thanks for advice. Does this plugin work on Vista? Toller
It worked fine when I tried it briefly.
