Custom Column - Example custom sort
This is an example of how to use the Dopus 11.5.1 and higher to create a custom column to allow custom sorting.
As requested by Julianon in Extreme custom sort.
In the code below, we define an array (config.sortOrder) that contains a list of the file extensions, and the sort value for that extension. Multiple columns can be configured.
// The OnInit function is called by Directory Opus to initialize the script add-in
function OnInit(initData) {
  // Provide basic information about the script by initializing the properties of the ScriptInitData object
  initData.name = "Custom Sort Column";
  initData.desc = "Adds that allows extension sorting in a custom order";
  initData.copyright = "2014 wowbagger";
  initData.min_version = "11.5.1"
  initData.version = "1.1";
  // Create a new ScriptColumn object and initialize it to add the column to Opus
  for(var i = 0; i < config.columns.length; ++i) {
    var cmd = initData.AddColumn();
    cmd.name = config.columns[i].name;
    cmd.method = "OnCustomSort";
    cmd.label = config.columns[i].name;
    cmd.autogroup = true;
    cmd.justify = "left";
var config = {
  columns: [{
    name: "CustomSort", //Sample sort config 1
    sortOrder: [{
        extension:"pdf",
        sortKey: "1"
        extension:"txt",
        sortKey: "2"
        extension:"tex",
        sortKey: "3"
        extension:"dvi",
        sortKey: "4"
        extension:"log",
        sortKey: "7"
        extension:"ptp",
        sortKey: "8"
    name: "CustomSort2", //Sample sort config 2
    sortOrder: [{
        extension:"txt",
        sortKey: "1"
        extension:"",
        sortKey: "1.5"
        extension:"log",
        sortKey: "2"
  debug: false
// Implement the OnCustomSort column (this entry point is an OnScriptColumn event).
function OnCustomSort(scriptColData) {
    var columnConfig = GetConfig(scriptColData.col);
    if(!columnConfig) return;
    var ext = scriptColData.item.ext.replace(".","").toLowerCase();
    var sortOrder = GetSortOrder(columnConfig, ext);
    if (!sortOrder) {
      scriptColData.value = config.debug ? "0:nomatch" : "";
      scriptColData.sort = 0;
      return;
    else
      scriptColData.value = config.debug ? sortOrder.sortKey + ":" + sortOrder.extension : sortOrder.extension;
      scriptColData.sort = sortOrder.sortKey;
function GetSortOrder(columnConfig, extension)
  var match = null;
  for(var i = 0; i < columnConfig.sortOrder.length; ++i) {
    if(columnConfig.sortOrder[i].extension.toLowerCase() == extension) {
      match = columnConfig.sortOrder[i];
      break;
  return match;
function GetConfig(key)
  var match = null;
    if(config.columns[i].name == key) {
      match = config.columns[i];
      break;
 return match;
How to use
Place the code (.vbs or .js) or .osp file into your Script AddIns folder (/dopusdata/Script AddIns).
You will then find the "CustomSort" column in Folder Options in the new Script category.
If you create your own custom sort scrips please share.
The filenames are in the format "somealphatext nnnnn_xxx", where I want to sort by "xxx".
function OnInit(initData){
  initData.name = "PnNumber";
  initData.desc = "Add a sortable column for pn number";
  initData.copyright = "myarmor";
  initData.version = "1.0";
  initData.default_enable = false;
  var col = initData.AddColumn();
  col.name = "Number";
  col.method = "OnNumber";
  col.label = "Number";
  col.justify = "left";
  col.autogroup = false;
  col.autorefresh=true;
// Implement the OnNumber column
function OnNumber(scriptColData){
  if (scriptColData.col!="Number") return;
  if (scriptColData.item.is_dir) {
    scriptColData.value = "";
    scriptColData.sort = 3;
  } else{
    var re=/^\w+ \d+[_-](\d+)/i;
    if (re.exec(scriptColData.item.name)){
      scriptColData.value = RegExp.$1;
    } else{
      scriptColData.value = "No Number";
Save the script with a .js extension into the addins folder.
Use at your own risk and whatnot, but feel free to adapt.
Answer to Sorting files by filename part.
Creates the columns Col1, Col2, and Col3. Allows independent sorting of each numeric part of the filename.
  initData.name = "MultiColSort";
  initData.desc = "Add sortable columns for numeric parts";
  initData.copyright = "";
  col.name = "Col1";
  col.method = "OnCol1";
  col.label = "Col1";
  col.name = "Col2";
  col.method = "OnCol2";
  col.label = "Col2";
  col.name = "Col3";
  col.method = "OnCol3";
  col.label = "Col3";
function ColCommon(colnumber,scriptColData)
  } else{
    var re=/^.+_(\d+)_(\d+)_(\d+)/i;
      switch (colnumber){
        case 1: scriptColData.value = RegExp.$1;break;
        case 2: scriptColData.value = RegExp.$2;break;
        case 3: scriptColData.value = RegExp.$3;break;
    } else{
// Implement the OnCol1 column
function OnCol1(scriptColData)
  if (scriptColData.col!="Col1") return;
  ColCommon(1,scriptColData);
// Implement the OnCol2 column
function OnCol2(scriptColData)
  if (scriptColData.col!="Col2") return;
  ColCommon(2,scriptColData);
// Implement the OnCol3 column
function OnCol3(scriptColData)
  if (scriptColData.col!="Col3") return;
  ColCommon(3,scriptColData);
Hi @wowbagger!
I would like to ask, if you have a tiny amount of time, how should i approach your script (where you can sort by extension) to display folders like in the original EXT Column, like <dir> or, with any custom string? Is it possible? I made some modifications, i have added a huge list of extensions sorted by your awesome custom column, but i would like it to display Folders more distinctively, and not by being empty?
Edit: Never mind! I did it somehow! I do not fully understand JS yet, im only creating VB macros in Excel at my workplace, but it seems i figured out the syntax :smiley:
Your script is very useful for me!
Nice one, Be sure to share your solution. Someone else might like it.
Yep, i will post it, had to get off my desk for some drinks, then back to configuring Opus :slight_smile:
So here is my version, not fully finished, i will implement a lot more extensions to sort by.
I added extensionout: to allow for a custom string for the extension if needed, also for directories, "<DIR>" can be changed to any character string to make directories pop out for better visuals.
I also modified the sorting numbers to minus, for example the EXE to -1.1 so it sorts as the first entry, instead the first after unspecified ones.
I am still learning the script syntax so if anyone has any suggestion, or simplifications, i would appreciate it.
  initData.desc = "Extension sorting in a custom order";
  initData.min_version = "12"
  initData.version = "1.2";
var config = {
  columns: [{
    name: "ext", //Sample sort config 1
    sortOrder: [{
        extension:"",
		extensionout:"",
		sortKey: "-100"
        extension:"exe",
        extensionout:"exe",
		sortKey: "-1.1"
        extension:"lnk",
        extensionout:"lnk",
		sortKey: "-1.11"
        extension:"bat",
        extensionout:"bat",
		sortKey: "-1.2"
        extension:"com",
        extensionout:"com",
		sortKey: "-1.2"
        extension:"msi",
        extensionout:"msi",
		sortKey: "-1.2"
        extension:"mp3",
        extensionout:"mp3",
		sortKey: "-2.0"
        extension:"wav",
        extensionout:"wav",
		sortKey: "-2.1"
        extension:"m4a",
        extensionout:"m4a",
		sortKey: "-2.2"
        extension:"wma",
        extensionout:"wma",
		sortKey: "-2.3"
        extension:"aup",
        extensionout:"aup",
		sortKey: "-2.8"
        extension:"ptx",
        extensionout:"ptx",
		sortKey: "-2.9"
        extension:"mp4",
        extensionout:"mp4",
		sortKey: "-3.0"
        extension:"avi",
        extensionout:"avi",
		sortKey: "-3.1"
        extension:"mpg",
        extensionout:"mpg",
		sortKey: "-3.2"
        extension:"mkv",
        extensionout:"mkv",
		sortKey: "-3.3"
        extension:"ogv",
        extensionout:"ogv",
		sortKey: "-3.4"
        extension:"vob",
        extensionout:"vob",
		sortKey: "-3.5"
        extension:"wmv",
        extensionout:"wmv",
		sortKey: "-3.6"
        extension:"flv",
        extensionout:"flv",
		sortKey: "-3.7"
        extension:"bmp",
        extensionout:"bmp",
		sortKey: "-4.0"
        extension:"jpg",
        extensionout:"jpg",
		sortKey: "-4.1"
        extension:"gif",
        extensionout:"gif",
		sortKey: "-4.2"
        extension:"png",
        extensionout:"png",
		sortKey: "-4.3"
        extension:"zip",
        extensionout:"zip",
		sortKey: "-5"
        extension:"7z",
        extensionout:"7z",
		sortKey: "-5.1"
        extension:"rar",
        extensionout:"rar",
		sortKey: "-5.2"
        extension:"txt",
		extensionout:"txt",
		sortKey: "-6"
        extension:"doc",
        extensionout:"doc",
		sortKey: "-6.1"
        extension:"pdf",
        extensionout:"pdf",
		sortKey: "-6.2"
        extension:"xml",
        extensionout:"xml",
		sortKey: "-6.3"
        extension:"xls",
        extensionout:"xls",
		sortKey: "-6.4"
        extension:"log",
        extensionout:"log",
		sortKey: "-7"
        extension:"log",
        extensionout:"log",
		sortKey: "-8"
  debug: false
    if (!sortOrder) {
      scriptColData.value = config.debug ? "0:nomatch" : "? "+ext;
      return;
    else if (scriptColData.item.is_dir)
      scriptColData.value = "<DIR>";
    else
      scriptColData.value = config.debug ? sortOrder.sortKey + ":" + sortOrder.extension : sortOrder.extensionout;
  var match = null;
      break;
  return match;
  var match = null;
      break;
 return match;
Edit: Oh and it also displays the unspecified extensions by putting a "?" in front of them but they are not sorted (only by filename)
