Does anyone know if custom column scripts get embedded into the full backups when you run them from the interface?
I want to make sure that I have a restoration plan should I have to reinstall or have a problem.
Thanks.
Thanks.
Yes all script add-ins and their configurations get backed up as part of Settings Backup & Restore.
Thank you! That backup is so simple and works so well. I wish other programs I have were like that.
