Hello,
I tried to customize the tray menu in order to add some items
- It seems that "Check from program updates" is missing as command, I couldn't find it and I use the search function in the customizer
- I added "Find Files" but it isn't working, not at least the way I expected. If a lister is opened then it works like it is expected, however if no lister is opened nothing happens. I expected that if no lister was opened, then a new lister should be opened with the find files panel expanded
I use the latest beta (12.21.2)
Am I missing something?
