Customize screen position of Move/Copy dialogs?
I suck at customizing DOpus, and can't find an answer to this one, so hoping someone else (Leo!!) knows ...
Is it at all possible to dictate where the dialogs for Moving/Copying files pop up, instead of them always coming up in the middle of the open lister one on top of the other? Even better would be if there's a way to get them to open/tile one below the other as you open them, where you want them???
By default most of my listers open at the far top left of my screen, and I manually drag the Copy/Move dialogs out of the way (then tile them if there are several) over to the far right side, leaving the centre of my screen for other stuff I am doing while DOpus does its thing. I can then see and monitor the status of my file operations while I work on something else. It'd be amazing if there is a way to automate the above behaviour?
Thanks!
Robin
I don't think there's any way to do that except using 3rd party tools that wait for certain windows to appear and move them around automatically.
Thanks, Leo - I thought I was being optimistic! :slight_smile:
