The customize shortcut (mini-toolbar) appears more slowly when opening Preferences to the Icons page compared to other pages.
Do you have lots of icon sets installed, or an icon set with lots of images in it?
I have 22 icon sets installed, with nearly 16k icons in total. The last four sets are SVGs.
| # | Icon Set | No of Icons |
| 1 | Internal Icon Set | 306 |
| 2 | Directory Opus 9 | 248 |
| 3 | FLUENT.dis | 369 |
| 4 | FLUENT_UI_APRICOT.dis | 394 |
| 5 | FLUENT_UI_BLUEBERRY.dis | 394 |
| 6 | FLUENT_UI_DUALTONE.dis | 397 |
| 7 | FLUENT_UI_MINT.dis | 394 |
| 8 | FLUENT_UI_MONOTONE.dis | 397 |
| 9 | FLUENT_UI_PLUM.dis | 394 |
| 10 | FLUENT_UI_RASPBERRY.dis | 394 |
| 11 | FLUENT_UI26_THIN_APRICOT.dis | 394 |
| 12 | FLUENT_UI26_THIN_BLUEBERRY.dis | 394 |
| 13 | FLUENT_UI26_THIN_DUALTONE.dis | 397 |
| 14 | FLUENT_UI26_THIN_MINT.dis | 394 |
| 15 | FLUENT_UI26_THIN_MONOTONE.dis | 397 |
| 16 | FLUENT_UI26_THIN_PLUM.dis | 394 |
| 17 | FLUENT_UI26_THIN_RASPBERRY.dis | 394 |
| 18 | IconSet Himmelsbla v1.2 Dual.dis | 630 |
| 19 | feather.dis | 287 |
| 20 | ms_icons.dis | 2,422 |
| 21 | tabler_io_filled.dis | 1,053 |
| 22 | tabler_io_outline.dis | 5,093 |
| Total | 15,936 |
Remove any you don't use (and maybe avoid or split up ones with thousands of icons you don't use) and it should process them a lot faster.
With the recently added option in 13.24.1 to disable icon sets, I disabled most of them, especially those with thousands of icons, but the delay is still there. Does this have to do with preview generation? Would a toggle option to disable icon previews speed up the process?
