Cut-and-paste from bin fails silently
Hello!
I have found a few times now that cutting a directory from the recycle bin fails silently. On those occasions:
  • I viewed the bin with Opus;
  • I used the keyboard to cut;
  • I proceeded to the actual desktop (not the desktop-shown-in-Opus-or-Explorer);
  • in order to (try to) paste, I used the keyboard again.
In trying just now through to replicate the issue, I failed. So either the bug is intermittent or else when I had the problem there was some sort of user error. Any thoughts, please?
But, ah: the lack of paste seems to occur when, after cutting, one selects something within Opus. Is this behaviour by design? If so, it seems a bit throwing.
Windows 10 Pro - 22H2 (2009: 19045)
Opus 13.15.3 Beta (but I think I had the problem before I installed a beta)
Does the same thing happen in File Explorer?
Copy and paste in Recycle Bin is handled by Windows rather than Opus, as is pasting to the Windows Desktop.
Thank you for the reply.
I am afraid that I have trouble now reproducing the problem even within Opus.
I propose to post a further comment here if and only if I can reproduce the problem with Opus and not with Explorer.
