@poletouche Did you also enable the "Show accent color on title bars..." option?
Also note that the selected color only applies to active windows. As far as I can tell, the inactive color is determined by Windows (i.e., the theme you choose).
I'm sure it's not the color of Windows, because when I turn on this option, the titlebar will display blue, and when I turn it off, it will be black
It's blue because you have blue selected above the checkbox in your screenshot.
This is beautiful. This is my favorite. This should be the default lister that comes with the program. Wow.
Thanks very much for the kind words. Glad you like the theme. You've inspired me to post an updated version ā just minor tweaks here and there, plus a few additional colours (e.g., file labels).
Dark Blue.dlt (304.5 KB)
Nice! Thanks again!
Thank you for this amazing theme! This is also my favorite.
Please do keep working on it whenever you have the time.
Thanks again!
Thanks very much, @Releno; I'm glad you like the theme. ![]()
I just installed/updated my own theme on my laptop and it appears as though File Labels are not saved as part of a theme. Is that correct? Personally, I think they should be. Is there a reason why they're not? Thanks.
To be honest, despite the hundreds of hours spent trying to tweak things, I still don't know how to check if what you're saying is true. ![]()
Different users may have completely different labels defined in their configs. It wouldn't really make sense for them to be part of themes.
@Leo Sounds good. Thanks so much for the response/confirmation.
Merry Christmas. ![]()
In case anyone is interested, here are the label colours I use with this theme:
Extract the "colorgroups.oxc" file and copy to your "/dopusdata/ConfigFiles" folder:
colorgroups.zip (801 Bytes)
Thanks!
