DataExtensions include file to work with collections, maps, vectors, arrays and dictionaries
While coding DOpus functionalities I often needed the same code to work with different data structures so I compiled this include script file to convert, enumerate, calculate length and differences of arrays, collections, dictionaries, maps and vectors.
inc_DataExtensions.opusscriptinstall (2.4 KB)
// DataExtensions
// (c) 2024 Felix Froemel
// This is an include file script for Directory Opus.
// See https://www.gpsoft.com.au/endpoints/redirect.php?page=scripts for development information.
// Called by Directory Opus to initialize the include file script
function OnInitIncludeFile(initData)
	initData.name = "Data Extensions";
	initData.version = "1.6 (2026-02-17)";
	initData.copyright = "(c) 2024 Felix Froemel";
	initData.url = "https://resource.dopus.com/t/dataextensions-include-file-to-work-with-collections-maps-vectors-arrays-and-dictionaries/58168";
	initData.desc = "Extensions to work with DOpus Collections, Maps, Vectors, JScript Arrays and Dictionaries. v" + initData.version;
	initData.shared = true;
// ******************* Conversion ******************* //
function ArrayToVector(arr)
	var vector = DOpus.Create.Vector();
	for (var i = 0; i < arr.length; i++)
		vector.push_back(arr[i]);
	return vector;
function CollectionToArray(collection)
    var array = [];
    ForEach(collection, function(item) { array.push(item); });
    return array;
function VectorToArray(vector)
	var array = [];
	for(var i = 0; i < vector.count; i++)
		var item = vector.back()
		array.push(item);
		vector.pop_back();
	return array;
function DictionaryToMap(dictionary)
	var map = DOpus.Create.Map();
	for (var key in dictionary)
		map(key) = dictionary[key];
	return map;
function MapToDictionary(map)
	var dict = { };
    KeyValueEnum(map, function(key, value) { dict[key] = value; });
	return dict;
// ******************* Enumeration ******************* //
function ForEach(enumerable, delegate)
    for (var enumerator = new Enumerator(enumerable); !enumerator.atEnd(); enumerator.moveNext())
        delegate(enumerator.item());
//abort if delegate returns false
function ForEachAbortable(enumerable, delegate)
        if(!delegate(enumerator.item()))
            return;
function KeyValueEnum(dict, delegate)
    for(var key in dict)
		delegate(key, dict[key]);
    for (var e = new Enumerator(dict); !e.atEnd(); e.moveNext())
        var key = e.item();
        var value = dict(key);
        delegate(key, value);
function DictToEnum(dict)
	var values = [ ];
		values.push(dict[key]);
	return new Enumerator(values);
// ******************* Length ******************* //
function CollectionLength(collection)
    var len = 0;
    for (var eColl = new Enumerator(collection); !eColl.atEnd(); eColl.moveNext())
        len++;
    return len;
function DictionaryLength(dict)
    var length = 0;
    for(var keys in dict)
        length++;
    return length;
// ******************* Array Extensions ******************* //
function ArrayContains(array, item)
	for(var i = 0; i < array.length; i++)
		if(array[i] === item)
			return true;
	return false;
//https://stackoverflow.com/questions/1187518/how-to-get-the-difference-between-two-arrays-in-javascript
function ArrayDifference(oldArray, newArray)
    // deal with empty lists
    if (oldArray == undefined)
        oldArray = [];
    if (newArray == undefined)
        newArray = [];
    // sort both arrays (or this won't work)
    oldArray.sort();
    newArray.sort();
    // don't compare if either list is empty
    if (oldArray.length == 0 || newArray.length == 0)
        return { added: newArray, removed: oldArray };
    // declare temporary variables
    var op = 0; var np = 0;
    var a = []; var r = [];
    // compare arrays and add to add or remove lists
    while (op < oldArray.length && np < newArray.length)
        if (oldArray[op] < newArray[np])
            r.push(oldArray[op]);
            op++;
        else if (oldArray[op] > newArray[np])
            a.push(newArray[np]);
            np++;
        else
            op++;
            np++;
    // add remaining items
    if (np < newArray.length)
        a = a.concat(newArray.slice(np, newArray.length));
    if (op < oldArray.length)
        r = r.concat(oldArray.slice(op, oldArray.length));
    return { added: a, removed: r };
function ArrayIndexOf(array, element)
	for (var i = 0; i < array.length; i++)
		if (array[i] == element)
			return i;
	return -1;
function ArrayRemoveItem(array, itemToRemove)
    var index = ArrayIndexOf(array, itemToRemove);
    if (index !== -1)
        array.splice(index, 1);
//https://stackoverflow.com/questions/8665862/efficient-algorithm-for-difference-of-array-and-a-known-subsequence
function ArrayRemoveItems(array, itemsToRemove)
    array.sort();
    itemsToRemove.sort();
    var diff = [];
    var i = 0, j = 0, n = array.length, m = itemsToRemove.length;
    while (i < n)
        if (j < m && array[i] === itemsToRemove[j])
            j++;
        else
            diff.push(array[i]);
        i++;
    return diff;
function Filter(array, filter)
    var result = [];
        if(filter(array[i], i, array))
            result.push(item);
    return result;
function Map(array, mapping)
    var result = [];
        result.push(mapping(array[i], i, array));
    return result;
function Reduce(array, reducer, initialValue)
    var accumulator = initialValue;
        if (accumulator !== undefined)
            accumulator = reducer(accumulator, array[i], i);
        else
            accumulator = item;
    return accumulator;
// ******************* Filter, Map and Reduce for enumerables ******************* //
function FilterEnum(enumerable, filter)
    var result = [];
    var index = 0;
    ForEach(enumerable, function(item) { if(filter(item, index++)) result.push(item); } );
    return result;
function MapEnum(enumerable, mapping)
    var result = [];
    var index = 0;
    ForEach(enumerable, function(item) { result.push(mapping(item, index++)); } );
    return result;
function ReduceEnum(enumerable, reducer, initialValue)
    var index = 0;
            accumulator = reducer(accumulator, item, index++);
        else
            accumulator = item;
    return accumulator;
v1.6 now has the Functionts Filter, Map and Reduce for Arrays and Enumerables
