This plugin is obsolete, unless you are using Directory Opus 8.
This plugin adds support to Opus 8 for the following image formats:
[ul][li]JPEG 2000 (JP2) -- Opus 9 now comes with a better, faster JPEG 2000 plugin.[/li]
[li]TGA (including alpha/transparency) -- Opus 9 now comes a better TGA plugin.[/li]
[li]PNM (PPM, PGM, PBM) -- Opus 9's new raw plugin supports a subset of PNM.[/li]
[li]Rasterfile (RAS) -- No Opus 9 equivalent as nobody seems to use this format. Shout if you need it.[/li]
[li]Raw Digital Camera formats, including Adobe DNG -- Opus 9 comes with a better raw plugin.[/li][/ul]
Author: Leo Davidson
Link: http://www.pretentiousname.com/jp2raw/
