I found a very promising FAQ post explaining how to make toolbar buttons and hotkeys to control Winamp from Dopus using a plugin called "gen_dde".
I played around with this for a while and here are my results. First, the successes:
With code (1), Winamp starts playing, but it doesn't play the file selected in Dopus; it simply plays the file that was already enqueued in Winamp. (This makes sense though.)
(1)
ddeexec play
ddeapp WINAMP
ddetopic System
"C:\Program Files\WinAMP\WinAMP.exe" /dde
With code (2), Winamp plays the file selected in Winamp, but it doesn't work for folders.
(2)
ddeexec play({filepath})
ddeapp WINAMP
ddetopic System
Now the failures. None of the following produced the desired result. I took the commands from the help text included with the gen_dde file.
(3)
ddeexec enqueue({filepath})
ddeapp WINAMP
ddetopic System
(4)
ddeexec next
ddeapp WINAMP
ddetopic System
(5)
ddeexec prev
ddeapp WINAMP
ddetopic System
(6)
ddeexec stop
ddeapp WINAMP
ddetopic System
(7)
ddeexec pause
ddeapp WINAMP
ddetopic System
Though I was certainly tickled to figure out something and make it work, neither (1) nor (2) are actually useful in practice. Just hitting Enter is a much easier way to get a file to play in Winamp since it's my default player. What I was really hoping for is a way to play folders. I usually do this through the context menu, where the "Play in Winamp" option works the same for files and folders. (Nevermind that I can't figure out how to hotkey context menus in Dopus! Aargh! I'll make a separate post for that.)
Any ideas? This would be a really awesome customization of Dopus!
I looked through all 143 googits for "gen_dde" but couldn't find any educational materials about this program. (I'm a total newbie to this fancy software stuff, but I'm trying to learn...)
By the way, the nunzioweb.com/sawgstuff/ site linked to in the FAQ post actually doesn't contain any "further details". It only has a link to the download.
Thanks,
Mike
