Maybe there should be one? I created a hotkey " + + + c" to enter customize mode more quickly now.
If there would be some kind of DO default for this, it could be much easier to guide people how to enter this special mode?
I noticed as a positive sideeffect when using the hotkey, the customize dialog does not point to the toolbar tab as it used to if opened by right clicking a toolbar and choosing "Customize..". This is very handy when editing keys or usercommands, since you don't need to switch tabs and scroll to find the item you worked on seconds ago again and again.
Mhh, but Leo, that's a key combo to open the menu and select an entry. o)
It's not a universal hotkey that works in every lister layout or on a german installation.
I get your position though, I was just thinking this is a good idea.
Pedantry. And if someone deletes all the default toolbars, it's their choice & responsibility to keep/re-create the things they need. With the power to customize everything comes the responsibility not to do stupid things.
Hotkeys are not strictly guaranteed to be the same across languages.
Why are you inventing & worrying about problems which have literally never happened in all the years Opus has existed?
We ensure you can always access Customize mode even with all toolbars & hotkeys removed, via the menu in the window icon.
Was just thinking on how to make life of multi-language supporters a bit easier, since a new hotkey won't exhaust anyone, but could save some time explaining where to click and what and how it's named in german e.g., which I never remember and cannot lookup quickly either. Anyway, I'm out.. thanks nonetheless.
