Current version of dopus on two computers. On my win7x64 system when I try to delete a locked file I get a file in use window that allows me to skip the locked file.
On my winxp-x32 system I get and error box that only lets me abort the delete.
I would like the skip window in the xp32 system. Is this a dopus setting, windows setting or just available in win7. Thanks.
Opus will give you Skip and Skip All options if you delete the files directly without using the recycle bin. (To do that, either turn off the recycle bin in Opus's preferences or create a button/hotkey/etc. which runs Delete NORECYCLE.)
When using the recycle bin you're at the mercy of Windows itself and it wasn't until Vista that the recycle bin interface was improved.
