Hello! o)
Sorry to bother you, but I have another zombie lister / not clickable problem whenever I delete a folder from a file collection (regular delete to recycle bin). First the "File collection warning" dialog appears, I click "ok", then the "Really delete?" dialog appears, I click "Ok".. then the lister wont' respond to mouse clicks anymore, it will just "bling" on the speakers. I have to kill DO and restart it to get going again.
You probably remember the RBTray.exe issue, it's exactly the same. I don't know when it started. I had it happen here and there in recent time, but I'm working with file collections more right now, it happens a lot.
I also have weird issues with the context menu in the file display not showing up on right mouse button (not always, sometimes it helps to press left mouse button after hitting the right button, then the context menu will come up). Sometimes I need to use this "menu" key on the keyboard on the lower right hand side to get to the context menu at all, because no mouse press whatever will give me the context menu. For some reason it can also happen in just one file display of a dual lister.
I have a memory dump from the "bling" situation, is there a way I can see myself what's the problem in the dump thing? Probably not, hu? o)
Maybe you have a quick idea, if not I would like to send the dump, but let's start easy.. o)
Thank you! o)
You will probably tell me it's one of my tools again, well.. I tried with all the things disabled, it still happens.
