Deleting files/folders by pressing D after right click
In my writing, 'desktop' always means wallpaper region of Windows. (Doesn't mean big computer body + big monitor)
I use Korean Windows 7 and Keyboard.
In Korean Keybaord, there is a English/Korean toggle key. I attached a pic..
The key right next to the spacebar is the English/Korean toggle key.
The corresponding Korean alphabet to English D, is called 'ieung'.
When I select some files/folders "In DESKTOP" and right click then and press D, then it says
"Are you sure to want to move blahblah to the Recycle bin ?" REGARDLESS of which langugage is selected.
When I select some files/folders "In DOPUS" and right click then and press D, then it says
"Are you sure to want to move blahblah to the Recycle bin ?" when ENGLISH is selected.
When I select some files/folders "In DOPUS" and right click then and press D, then nothing happens,
when KOREAN is selected. In fact a small thing happens, the 'ieung' appears
on the left corner of the monitor. (But it has no function - If I mouse click any blank space or do any kind of job, it disappears immediately.) But this phenomenon is not confined to dopus, this happens in photoshop, goldwave... in many commercial programs. But this phenomenon does not happen in text editors or games. For example, pressing D in StarCraft will make a Zerg Drone regardless of which language is selected.
In short, can I delete files/folders in Dopus, by pressing D even when Korean is selected ?
(I know there is a Delete Key but it is placed on the right corner of the keyboard... impractical position)
You can map other hotkeys to the Delete command (or use the button on the toolbar) to avoid having to open the menu at all.
But if you definitely want to use the context menu, the keyboard shortcuts are defined in the menu itself. You can edit it under Settings > File Types > All Files and Folders.
Please link your account if you need more detailed help.
