Hi
I want to delete files into R bin I have the "delete into R bin if possible" selected in preferences but deleted files are not going there.
I am deleting from other hard disks any idea what I am missing here ?
Thank you
Hi
Thank you
What happens in File Explorer for the same drives?
Ohh yes, I got it now, it happens only on the virtual cloud drive, if I delete it from the physical drive that syncs with the virtual one it deletes into R Bin indeed.
Thank you
