slouw
December 8, 2021, 6:01am
1
I am like a bad smell wont go away
Now I am trying to get something intelligent from a Detached Dialog
I see a sample code fragment Scripting > Example Scripts > Script Dialog Example in VB (Soooo passe OMG!) which relies on msg.control to interact. I cannot get anything presently from my mock up see below.
First I tried using Dlg.Control which I have successfully used in a simple dialog setup see related post . This does not work for me.
Upon reading the instructions (I know I know. Desperate times) for the Msg property
I then added various .Msg methods see also below. Nothing.
What am I doing wrong?
function OnClick(clickData)
DOpus.ClearOutput;
DOpus.Output("001000 Start");
// 001000
// 001000 Start
// 001000
var Dlg = DOpus.Dlg;
Dlg.window = clickData.func.sourcetab;
Dlg.template = "Dialog_1";
Dlg.detach = true;
Dlg.Show();
// 002000
// 002000 Msg Loop
// 002000
DOpus.Output("002000 Msg Loop");
while (true) {
var Msg = Dlg.GetMsg();
if (!Msg.result) break;
DOpus.Output(" 000 Combo_Box_Alpha1 index = "& Dlg.Control("Combo_Box_Alpha1").value);
DOpus.Output(" 010 Msg Event = = " + Msg.event);
DOpus.Output(" 020 Msg.Control = " & Msg.Control);
DOpus.Output(" 030 Msg.Dialog = " & Msg.Dialog);
DOpus.Output(" 040 Msg.Index = " & Msg.Index);
// 002000
// 002000 Exit Loop
// 002000
DOpus.Output("002000 Exit Loop");
DOpus.Output(" 010 Return code = " + Dlg.result);
DOpus.Output(" 020 Combo_Box_Alpha1 index = " & Dlg.Control("Combo_Box_Alpha1").value);
DOpus.Output("009000 End");
<resources>
<resource name="Dialog_1" type="dialog">
<dialog fontsize="8" height="60" lang="english" standard_buttons="ok,cancel" title="Prepare to Go" width="252">
<control height="40" name="Combo_Box_Alpha1" type="combo" width="78" x="12" y="24">
<contents>
<item text="ComboBox Primary" />
<item text="ATOTaxInv" />
<item text="BloodP" />
<item text="CCP Timesheet" />
<item text="CCP Payslip" />
<item text="CCP Exp" />
<item text="CCP Photos" />
<item text="COD" />
<item text="CSA" />
<item text="Dogs Ellie" />
<item text="Dogs Kirra" />
<item text="Dogs Both" />
<item text="Dogs Tiny" />
<item text="Dogs Nala" />
<item text="Dogs" />
<item text="Daily Telfast" />
<item text="Dinner" />
<item text="E" />
<item text="F" />
<item text="Gym" />
<item text="Hint" />
<item text="House" />
<item text="Inv" />
<item text="Ingrid" />
<item text="J" />
<item text="Kids" />
<item text="Luke" />
<item text="Maxalt 1.0" />
<item text="mDaily" />
<item text="Maxalt 0.5" />
<item text="Maxalt STOCK" />
<item text="Netbank" />
<item text="ODempsey" />
<item text="o1Poster" />
<item text="o2 Books" />
<item text="PCCET" />
<item text="Post RTS" />
<item text="Quotes" />
<item text="Research Furnature" />
<item text="RJ" />
<item text="RJ Netball" />
<item text="Research" />
<item text="StC" />
<item text="Tomb" />
<item text="ThumbLHS" />
<item text="Trading" />
<item text="u1History" />
<item text="u2Culture" />
<item text="vMovies" />
<item text="Vaya" />
<item text="Work" />
<item text="xStorage" />
<item text="Y" />
<item text="zxc" />
<item text="1ThumbF" />
<item text="2Twice" />
<item text="3" />
<item text="0" />
</contents>
</control>
<control halign="left" height="12" name="Suffix" tip="Suffix" type="edit" width="64" x="168" y="24" />
<control height="40" name="Combo_Box_Beta2" type="combo" width="54" x="102" y="24">
<contents>
<item text="ComboSec" />
</contents>
</control>
</dialog>
</resource>
</resources>
Jon
December 8, 2021, 6:07am
2
VBScript uses & to concatenate strings but JScript uses +. You seem to have a mix there.
slouw
December 9, 2021, 4:21am
3
Ah thx @Jon mybad
Notice I am at long last converting this script to JS from VB!
slouw
December 9, 2021, 9:08am
4
Thanks for the help so far.
Below represents my efforts to extract more meaningful information out of my dialog...unsuccessfully as you can see.
My efforts are based around what I understand to be the relevant object namely the DialogListItem
In particular I am after the entry that is selected from the pulldown menu in the Combo_Box referenced.
When I try using the Control .GetItemByName method I get the error shown.
DOpus.ClearOutput;
// 001000
// 001000 Start
// 001000
Dlg.detach = true;
Dlg.Show();
// 002000
// 002000 Msg Loop
// 002000
i = 0;
while (true)
DOpus.Output(" 000 Iteration ======================================================"+ i);
DOpus.Output(" 000 Combo_Box_Alpha1 index = "+ Dlg.Control("Combo_Box_Alpha1").value);
DOpus.Output(" 010 Msg Event = " + Msg.event);
// DOpus.Output(" 020 Msg.Checked = " + Msg.Checked);
DOpus.Output(" 020 Msg.Data = " + Msg.Data);
DOpus.Output(" 020 Msg.Icon = " + Msg.Icon);
DOpus.Output(" 020 Msg.Selected = " + Msg.Selected);
DOpus.Output(" 020 Msg.Subitems = " + Msg.Subitems);
DOpus.Output(" 020 Msg.Control = " + Msg.Control);
DOpus.Output(" 030 Msg.Dialog = " + Msg.Dialog);
DOpus.Output(" 040 Msg.Index = " + Msg.Index);
DOpus.Output(" 040 Msg.Name = " + Msg.Name);
Combo_Box_1 = Control.GetItemByName("Combo_Box_Alpha1")
// 002000
// 002000 Exit Loop
// 002000
DOpus.Output(" 020 Combo_Box_Alpha1 index = " + Dlg.Control("Combo_Box_Alpha1").value);
This is the error I am getting currently:
I have left off more information e.g. the dialog XML for brevity. Happy to add if needed.
Appreciate any hints or suggestions....
Have a look at my SelectByDate command which uses a detached dialog.
I advise you to create variables for your dialog controls before going into the msg loop so that you can interact with them later on easily without always referencing the dialog
var Combo_Box_Alpha1 = dlg.Control("Combo_Box_Alpha1");
while(true) {
var val = Combo_Box_Alpha1.value;
You already did it the right way when printing the combo index.
In the end you use Control without referencing the dialog. Docs say
Use the Dialog .Control method to obtain a Control object
slouw
December 13, 2021, 5:10am
6
So my question above was about getting the text for the selected combo box entry:
"In particular I am after the entry that is selected from the pulldown menu in the Combo_Box referenced "
It seems I have a solution as per below.
It is necessary to dig into the DailogListItem to get its name.
I was looking at the parent Control object.
The hierarchy of objects is as follows
DOpus > Dialog > Control > DialogListItem
DOpus.ClearOutput;
DOpus.Output("001000 Start Rev_003");
// 001000
// 001000 Start
// 001000
Dlg.window = clickData.func.sourcetab; // Parent Window of the dialog
Dlg.template = "Dialog_1"; // GUI Script Dialog defined in Resources
Dlg.detach = true;
Dlg.Show();
// 002000
// 002000 Msg Loop
// 002000
Control_Combo_BoxA1 = Dlg.Control("Combo_Box_Alpha1") // Returns a Control object
i = 0;
while (true)
DOpus.Output(" 000 Combo_Box_Alpha1 value = "+ Dlg.Control("Combo_Box_Alpha1").value);
DOpus.Output(" 005 Control_Combo_Box_Al value = "+ Control_Combo_BoxA1.value);
DOpus.Output(" 006 Control_Combo_Box_Al count = "+ Control_Combo_BoxA1.count);
DialogListItem_Combo_BoxA1 = Control_Combo_BoxA1.value; // Returns a DialogListItem
DOpus.Output(" 007 DialogListItem.name = "+ DialogListItem_Combo_BoxA1.name);
DOpus.Output(" 008 DialogListItem.index = "+ DialogListItem_Combo_BoxA1.index);
// Combo_Box_1 = Control.GetItemByName("Combo_Box_Alpha1")
// 002000
// 002000 Exit Loop
// 002000
DOpus.Output(" 030 Control_Combo_Box_Al value = " + Control_Combo_BoxA1.value);
// DOpus.Output(" 040 Control_Combo_Box_Al count = " + Control_Combo_BoxA1.count); // Outside loop not work for some reason?
DOpus.Output(" 040 DialogListItem.name = "+ DialogListItem_Combo_BoxA1.name);
DOpus.Output(" 050 DialogListItem.index = "+ DialogListItem_Combo_BoxA1.index);
This is the Dialog Box that pops up and the debug output for selecting Item4 and clicking ok
