Determine if a column script is being used in rename dialog
What is the best way to determine if a script which adds columns (in this case, my ebook columns script) is being used in the advanced rename dialog instead of to add columns to a lister?
I've noticed a problem with my script - it crashes in the rename dialog because I use a BusyIndicator when building the columns.
The only way I see to get around this is to check if scriptColData.tab.visible is true and only use the indicator when it is? Have I missed another option? Thanks.
I think ScriptColumnData.tab will be 0 in that case.
That works fine. Thanks Jon.
