This is a preliminary, beta release. Translations may not be fully up-to-date and some English text may appear in non-English versions.
Download:
Universal version (all supported languages)
Deutsche Version
中文版
Changes since 12.25.1:
- Fix/workaround for Windows 11's bug which caused the Desktop Double-Click feature to open Listers from just a single-click if desktop icons were turned off. IMPORTANT: You must **reboot** after installing the update for this change to take effect.
- Where two paths point to the same drive via the Windows subst command, moving files between them is now done via a fast rename rather than a slow copy-then-delete.
- When undoing a folder creation, the deletion will do nothing if the folder contains any files or non-empty folders. This is to avoid accidentally deleting items created after the folder was created. ("Empty folder" here means a folder with zero files below it and at most one child "empty" folder which itself is either empty or has one empty child folder, and so on, recursively. So you can still undo a multi-level folder creation, as long as nothing extra has been created within the directories.)
- Reverted change in previous beta involving Copy HERE CREATEFOLDER, as it fixed one rare situation but created another. A larger change is required, and we want to test that internally for a while before we release it.
- You can now use the Copy MAKESFX HERE command on archives within collections (e.g. Find Results), where it will create the new exe in the same folder as the archive. (Similar functionality already existed for extracting archives in collections to their own parent folders.)
- Fixed problem with Rename command where if you used the FROM argument without the PATTERN argument, and the FROM argument contained a wildcard it would try to use that as the value for PATTERN even if it contained wildcard characters that PATTERN doesn't support. Now it will only do this if the only wildcard char used is a *.
- If Rename uses FROM as the value for PATTERN, it now unescapes any wildcard chars that are also valid filename chars automatically.
- Fix for rare crash in the sound player when a sample stops playing and auto-close is on.
- Scripting FSUtil.SameDrive method has a new s flag to test if two paths point to the same drive via drive letters made via the Windows subst command.
