This is a preliminary, beta release. Translations may not be fully up-to-date and some English text may appear in non-English versions.
Download:
Universal version (all supported languages)
Deutsche Version
中文版
Changes since 12.30:
- Fixed problem reading empty directories with SFTP servers which return a completely empty list for them (missing the usual "." and ".." entries).
- Fix for viewer status bar's text potentially appearing bold (overprinted) if status icons were displayed on it.
- Added a kludge to block duplicate DropBox context menu items on Windows 11. (The actual cause is a DropBox bug).
Scripting:
- DialogListColumns object has new GetDisplayOrder and SetDisplayOrder methods for changing the order columns are displayed on-screen, including the ability to move secondary columns before the primary column which usually appears first.
- Added Control.redraw property. Set to false to disable redraw in some types of control (e.g. listviews) while making multiple changes to them. Set back to true to redraw changes.
- File objects (representing open file handles which are being read/written) can now be passed directly to Command.AddFile and similar methods without conversion. (Provided the File object has a path; not for virtual files that only exist in memory.)
- Fixed rendering issue with group boxes with no title set in script dialogs
