This is a beta release. It may be unstable. Some text may not be translated yet. Use at your own risk!
Download manually, or use Help > Check for Program Updates (if beta versions are enabled in Preferences / Internet / Updates).
The previous beta's folder tab drag & drop changes now work with third-party software which puts a transparent window over the whole screen.
The Unattended Errors UI's Retry button has been removed, at least temporarily, as it was not always reliable.
Fixed MP3 bitrate calculation on certain files.
