Hello,
I wanted to include tera copy into directory with your tutorials :
[Copy & Move with TeraCopy)
"Go back again to to Settings -> Filetypes -> All Files and Folders.
Edit that, and make sure the Events tab is active.
This time, double-click on the Drag-and-Drop + Shift entry.
The command to be entered this time is "C:\Program Files\TeraCopy\TeraCopy.exe" Move {allfilepath$|filem} {destpath}"
but when I drag and move, teracopy don't start and I have an tmp file. The file is not copy ... if you have a solution for this I'm interrested.
Thx a lot
