Directory Opus Chrome Power Icons
This icon set doesn't replace any standard icons and instead just adds new ones.
To add these icons to your Directory Opus Configuration:
- Download the attached .zip file
- Extract chrome_power.dis
- In Directory Opus, open Settings Menu - Preferences
- In Preferences, goto Display - Toolbar Icons
- Click on the Import button (disk with up arrow), or press +
- Browse to and select the chrome_power.dis file, and click Open
The Icons look much better if you disable the highlighting effect:
- Go to Settings -> Preferences -> Display -> Toolbars
- Set Image highlighting effect to None
chrome_power.zip (16.1 KB)
