I have my default .jpg viewer set to "Windows Photo Viewer", but when I double click on a .jpg image, it opens in the Directory Opus viewer.
If I use Explorer, the .jpg image opens in the correct "Windows Photo Viewer".
Any ideas?
Any ideas?
Preferences --> File Operations --> Double click on Files then uncheck the box for Use internal picture viewer.
Regards, AB
Thanks.
I have never had to change that setting before.
The file is still associated, so I don't know what is wrong.
But at least that fixed the problem.
