I "spoke" with the people at ConceptWorld, for, in using DirPosu, RX wasn't tracking activity *(as it does for Explorer and Total COmmander). What they told me was
"Basically the Dopus command line [ see graphic] creates a shortcut under ‘Recent Documents’. You would need to contact Dopus support to check if the command line is fine to create a shortcut under Recent Documents.
The current command line may create a shortcut to file and not folder (not sure). So you would need to ask them how to create a shortcut to the folder double clicked in Dopus.
Does Copy FILE become Copy FOLDER or what?
Will the command, as shown, when placed in the "Settings / File Types / All Files and Folders / Left Double-Click accomplish this -- create the shortcut in Recent Documents?
Regards,
Chuck Billow
