Hello,
I've configured an Info Tip for the Archives File Type Group to show the first image (if available) of their contents as a thumbnail.
{thumbnail:0:512}
I'd like to restrict its use to local units only, so external mounted ones doesn't get affected, preventing the downloading of the archive.
In this particular case the unit is mounted by rclone and WinFsp.
I guess this is possible but i couldn't find the option.
Thanks for reading.
The settings under Preferences / File Displays / Options allow you to completely disable Info Tips for some drive types.
I don't think there is currently a way to disable only the thumbnail on certain drive types, however.
