Program: Directory Opus 12.19 x64
O.S. Windows 7 64 bit SP1
I've been trying to use the relatively new Command Modifier @disableifpath in buttons, but have run into some unexpected behavior. Here is a simple example button script:
@disableifpath:/desktop
@disableifpath:/mycomputer
@disableifpath:/trash
@disableifpath:/network
@disableifpath:/homegroup
@disableifpath:D:\Downloads
Go REFRESH=all
This button will simply refresh the Lister display(s), but the button is supposed to be disabled if the active display is in a folder alias or path listed above (Desktop, Computer, Recycle Bin, Network, Homegroup, or D:\Downloads folder).
The button is properly disabled only when the active display path is the Desktop or D:\Downloads. It does not work for Computer, Recycle Bin, Network (these are built-in aliases), or Homegroup (an alias I created). I suspect the following:
- I'm not understanding something
- I've not implemented the code correctly
- A windows 7 problem
- A DOpus program bug
I'm aware that there have been some issues with the @disableifpath Command Modifier, but I'm using almost the latest version of DOpus that should have had these bugs worked out.
Thanks,
Dan
