Hi all,
Recently I have been trying to use a path folder format to customise the way a particular path is displayed. The path contains media data and I'd like to show it in thumbnail mode, but I'd also like to choose some META data to display underneath the thumbnail (e.g. Title). I have managed to set up the path folder format so that it shows thumbnails, and I have also set it to display certain META data. Unfortunately the META data no longer displays when the folder path is set to thumbnail mode. I checked the thumbnail file display mode settings and I notice that it is possible to set up to 10 lines to use for the label. But there is no option to choose custom data to display in this label - it just shows the filename with optional file size and rating overlay (I like the rating overlay!).
My questions are:
- Is there any interest in applying these preferences in future versions of DOPUS?
- I have programming experience, though I haven't gone much further than a few simple scripts with DOPUS. Would it be possible to apply this level of customisation via some plugin? If so, what's the best way to get me started down that road?
Thanks all,
BH.
