When I copy I can only see the exact directory the file is in. I would like to see the entire path that holds the file I'm Moving or Coping. Any help is needed.
Thanks
Bob
Thanks
Bob
That´s strange. By default Opus uses the paths in the listers title bar on both sides. I don´t even know a way
to turn them off. So the location you are coyping to is that one displayed in the opposite lister title (that would be
the red counterpart of the green bar of the active lister in the image).
