DNG thumbnail previews not showing in flat view
Hi. I just noticed that DNG thumbnail previews are not showing when I use flat folder view. They work fine in normal view. Not a biggie, but might be a small bug which has gone under the radar.
I am using latest Windows 11, with PowerToys if that helps.
Cheers
Is it Flat View itself, or are some of the files taking a long time to thumbnail, holding up all the threads which are generating the thumbnails?
Flat View shouldn’t make a difference, other than adding a lot of extra files into the mix. I always test the raw plugin using flat view after changes to it, so I know it was working recently, at least.
Do thumbnails work after exiting Flat View, or are they still stuck?
