I recently installed DO 11.18 x64 on a new Dell Inspirion 15 laptop running Win 10 and am having a major delay problem with DO that I have never experienced before. I am running the current install in eval mode and am planning on buying a license soon. But I have been a DO user for a long time and have a licensed copy running on my other computer and have never experienced anything like this before.
Here's what I'm seeing.
On Windows startup DO loads in the system tray in a timely manner... actually quite fast as I am running on an SSD. However, when I open a new lister it takes up to 60 sec to open. This only happens when I open the first lister. After that I can close and reopen a new lister and that comes up in an acceptable amount of time. So it's only happening on the first lister opened.
After opening a lister and navigating to folders, depending on the type of folder I navigate to I am also experiencing a freeze in DO for 30+ seconds where the mouse cursor spins and the lister display stays blank until it finally loads the folder. Not quite sure of this, but am pretty confident that this only seems to happen on folders with a lot of executable files. For instance if I navigate to the folders where I have portable versions of the Nirsoft and Sysinternals program suites where there a lot of exes. After those folders load, I don't have any problems re-navigating back to those folders again unless I do something like open a new lister or close the current lister and open a new one. Then I see the same freeze issue again.
I browsed the DO forum and did find Leos post on diagnosing delay issues and tried the suggestions for disabling Windows shell extensions to try and isolate the problem, but those procedures don't work here. I use ShellEx View x64 to disable the suggested shell extensions and also the shell extensions that I am using in DO. I've also disabled all the shell extensions I know I am using in DO by blacklisting them in DO preferences but again with no luck. I've also tried disabling all the DO plugins but that doesn't work either. I am only running one script... aussieboykie's Beyond Compare plugin v 2.4AB and have also tried removing that with no luck.
I'm hoping that someone can suggest a debug process I can go through to isolate this, such as tracing DO execution for the two problems I described above.
Please advise. TIA Mark.
